Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Carefully remove the front-facing camera from the iPad, threading its cable through the slot cut near the bottom of its socket in the rear case. Carefully remove the front-facing camera from the iPad, threading its cable through the slot cut near the bottom of its socket in the rear case. Carefully remove the front-facing camera from the iPad, threading its cable through the slot cut near the bottom of its socket in the rear case.
  • Carefully remove the front-facing camera from the iPad, threading its cable through the slot cut near the bottom of its socket in the rear case.
Retirez avec précaution la caméra frontale de l'iPad, en faisant passer sa nappe à travers la fente taillée près du bas de sa prise dans la coque arrière.
