Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
Apple boasts an impressive seven hour battery life from the new MacBook, matching that of the 13" and 15" MacBook Pros. The battery is held in with both tri-wing and Phillips screws, an indication that Apple doesn't want you replacing the battery yourself. One of the three tri-wing screws is beneath a warning label in the top left corner of the battery.
  • Apple boasts an impressive seven hour battery life from the new MacBook, matching that of the 13" and 15" MacBook Pros.
  • The battery is held in with both tri-wing and Phillips screws, an indication that Apple doesn't want you replacing the battery yourself.
  • One of the three tri-wing screws is beneath a warning label in the top left corner of the battery.
  • For most repairs, removing the battery is not necessary, you just need to disconnect it from the logic board. You can use a spudger or your fingernails to lift battery connector straight up out of its socket on the logic board.
Insérez ici votre traduction
