Aller au contenu principal
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 16 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: étape 0, image 1 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: étape 0, image 2 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: étape 0, image 3 de 3
  • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Insérez ici votre traduction
