Aller au contenu principal
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 16 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 21
Étape 21
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: étape 0, image 1 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: étape 0, image 2 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: étape 0, image 3 de 3
  • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
  • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
  • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
  • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
  • Leave the pick in place before moving on.
Insérez ici votre traduction
