Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
Continue to separate the adhesive along the top edge of the display. As you slice along this edge, you may bump into the camera and proximity sensor housed here. Don't pry aggressively, just work around them. As you slice along this edge, you may bump into the camera and proximity sensor housed here. Don't pry aggressively, just work around them.
  • Continue to separate the adhesive along the top edge of the display.
  • As you slice along this edge, you may bump into the camera and proximity sensor housed here. Don't pry aggressively, just work around them.
Continuez à faire céder l'adhésif le long du bord inférieur de l'écran.
Vous risquez de heurter la caméra et le capteur de proximité logés ici. Ne forcez pas, mais contournez-les.
