Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
The motherboard is removable after the heat sink assembly, and after some (mostly labeled) connectors are disconnected. The motherboard contains the CPU, volume buttons, and ports.
  • The motherboard is removable after the heat sink assembly, and after some (mostly labeled) connectors are disconnected. The motherboard contains the CPU, volume buttons, and ports.
  • High-wear components like ports and buttons make for a very expensive replacement when they're soldered to the motherboard.
  • The placeholder SIM tray comes out without a fuss in this version. Prior editions required complicated motherboard removal, so this is a nice change.
  • The speaker can be removed at the same time as the motherboard, but it's slightly easier with the motherboard removed. Its modularity and simple cable layout is appreciated.
Insérez ici votre traduction
