Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 7 tutoriels qui comprennent cette étape.
Traduction de l’étape 2
Étape 2
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction cup to create a gap between the glass and the frame.
Insert an opening pick into the gap.
[* black] Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible. | |
[* icon_note] If the phone's rear glass is cracked, the suction cup may not stick. Try [https://d3nevzfk7ii3be.cloudfront.net/igi/4MmKE22Cy2MavVZU|lifting it with strong tape|new_window=true], or superglue the suction cup in place and allow it to cure so you can proceed. | |
[* black] Lift the rear glass with the suction cup to create a gap between the glass and the frame. | |
[* black] Insert an opening pick into the gap. | |
+ | [* icon_caution] Don't attempt to insert a pick between the back glass and the frame before creating a gap. The glass is covered with foil from the inside, and by not creating a gap, you risk inserting the pick between the glass and the foil instead, which would permanently damage the foil and ruin the solid color of the back panel. |
[* icon_note] If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating. |
