Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board. Use the small flat head screw driver to gently lift the brown clamp.
  • With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board.
  • Use the small flat head screw driver to gently lift the brown clamp.
  • The clamp will release the battery ribbon cable from the logic board, freeing the battery.
Insérez ici votre traduction
