Aller au contenu principal
Depth Sensor Node Streambed Installation Procedure
Anglais
Français
Traduction de l’étape 1
Étape 1
Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: étape 0, image 1 de 3 Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: étape 0, image 2 de 3 Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: étape 0, image 3 de 3
  • Clear large rocks from the streambed to make it easier to install the strut channel.
  • Place cleared rocks downstream so they do not damage the node during a storm.
  • Set 5 ft steel strut channel into place.
  • Ensure the open side of the strut channel faces south so that the solar panel receives maximum sunlight! Addtionally, be careful not to deform the steel strut channel too much. A bit of deformation is okay.
  • Use the post pounder to drive the strut channel 3 ft into the stream bed.
Insérez ici votre traduction
