Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 8 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Apply a suction cup to the heated bottom edge of the back cover. Make sure you did not mistake the screen side for the back cover side. If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
  • Apply a suction cup to the heated bottom edge of the back cover.
  • Make sure you did not mistake the screen side for the back cover side.
  • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
  • Lift on the suction cup with strong, steady force to create a gap.
  • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
  • Insert an opening pick into the gap.
Posez une ventouse sur la partie inférieure du téléphone.
Si votre coque arrière est méchamment fissurée, recouvrez-la d'une couche de ruban adhésif d'emballage transparent pour que la ventouse puisse adhérer.
Tirez fermement et constamment sur la ventouse pour ouvrir un espace.
Vous devrez faire un certain effort selon l'âge de votre téléphone. Si vous avez du mal, faites chauffer plus et recommencez.
Insérez un médiator dans l'espace.
[* black] Apply a suction cup to the heated bottom edge of the phoneback cover.
[* icon_caution] Make sure you did not mistake the screen side for the back cover side
[* icon_note] If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
[* black] Lift on the suction cup with strong, steady force to create a gap.
[* icon_note] Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
[* black] Insert an opening pick into the gap.
