Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 10
Étape 10
Carefully lift the top end of the motherboard away from the frame. Remove the motherboard. When you reinstall the motherboard, be careful not to trap any flex cable connectors underneath it.
  • Carefully lift the top end of the motherboard away from the frame.
  • Remove the motherboard.
  • When you reinstall the motherboard, be careful not to trap any flex cable connectors underneath it.
  • It may be difficult to reposition the motherboard around the earpiece flex cable. You can gently pry up the earpiece speaker, install the motherboard, and reinstall the earpiece speaker.
Soulevez délicatement la partie supérieure de la carte mère hors du châssis.
Ôtez la carte mère.
Au moment de réinstaller la carte mère, faites attention à ne coincer aucun connecteur de nappe en dessous.
[* black] Carefully lift the top end of the motherboard away from the frame.
[* black] Remove the motherboard.
[* icon_reminder] When you reinstall the motherboard, be careful not to trap any [https://d3nevzfk7ii3be.cloudfront.net/igi/QmrdmtbKsVsWJtuD.large|flex cable connectors|new_window=true] underneath it.
[* icon_reminder] It may be difficult to reposition the motherboard around the earpiece flex cable. You can gently pry up the earpiece speaker, install the motherboard, and reinstall the earpiece speaker.
