Aller au contenu principal
Canon PowerShot SX60 HS Back Panel Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Canon PowerShot SX60 HS Back Panel Replacement: étape 0, image 1 de 2 Canon PowerShot SX60 HS Back Panel Replacement: étape 0, image 2 de 2
  • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
  • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
  • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
  • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
Insérez ici votre traduction
