Aller au contenu principal
Canon PowerShot SX60 HS Side Panel Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Canon PowerShot SX60 HS Side Panel Replacement: étape 0, image 1 de 3 Canon PowerShot SX60 HS Side Panel Replacement: étape 0, image 2 de 3 Canon PowerShot SX60 HS Side Panel Replacement: étape 0, image 3 de 3
  • Remove the 4mm #00 Philips screw located on the top left corner beneath the front panel.
  • Remove the 5mm #00 Philips screw located on the top left corner beneath the front panel.
  • Remove the 5mm #00 Philips screw located on the top of the left side panel near the microphone connection.
  • Remove the 4mm #00 Philips screw located on the bottom left corner beneath the front panel.
  • Using a black spudger, unclip the orange wire ribbon on the lower left corner of the motherboard and then remove it using the nylon tipped tweezers.
  • The side panel is now free and can be removed by pulling the panel to the left.
Insérez ici votre traduction
