Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Traduction de l’étape 3
Étape 3
Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
