Traduction de l’étape 21
Connecting the fuse. The fuse is between + “a. Battery” and - “b. Battery” and should still be on the left carrier.
Very carefully peel off the tape that holds the fuse to the left carrier with the hope it can be reused. The purpose of the tape is to keep the fuse from rattling. Not so much as to reduce noise, but to prevent the connection from breaking
Strip about 1cm of heat shrink from each lead of the fuse
Make a U-bend at the end of each fuse lead 029
Ensure that the + lead of “a. Battery” will bend into the gap (see picture 030) This would be a good time to ensure that all of the other batteries.
“b. Battery” lead points to “c. Battery” “c. Battery” lead points to “d. Battery” “d. Battery” lead points to “c. Battery”
Cut red + lead of “a. Battery” leaving about 4cm. 031 Strip 1cm from lead. Tin lead
