Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 7
Étape 7
Remove the 6 screws which hold the LCD to the mount. Use a spudge tool to check the amount of tension between the LCD and the mount. If the LCD comes away from the mount easily, remove gently, lower from the top down (pull towards you) and rest it on the keyboard. If the LCD shows signs of tension, do not force it off of the frame. Use either a heat gun or dehydrator (preferable) to loosen the adhesive behind the panel.
Remove LCD Panel
  • Remove the 6 screws which hold the LCD to the mount.
  • Use a spudge tool to check the amount of tension between the LCD and the mount. If the LCD comes away from the mount easily, remove gently, lower from the top down (pull towards you) and rest it on the keyboard.
  • If the LCD shows signs of tension, do not force it off of the frame. Use either a heat gun or dehydrator (preferable) to loosen the adhesive behind the panel.
  • If placing in a dehydrator, leave the laptop (WITHOUT BATTERY) for 30 minutes at high heat.
  • When removing from the dehydrator (if required) move quickly to remove the LCD from the frame. The heat will dissipate quickly,
Insérez ici votre traduction
