Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 1
Étape 1
If your battery has two black tabs near the bottom corners, the battery is held in place by stretch-release adhesives. If that's the case,  follow this guide instead to complete your battery replacement. Before you begin prying, note that the battery is held in place by two adhesive strips. Before you begin prying, note that the battery is held in place by two adhesive strips.
Battery adhesives
  • If your battery has two black tabs near the bottom corners, the battery is held in place by stretch-release adhesives. If that's the case, follow this guide instead to complete your battery replacement.
  • Before you begin prying, note that the battery is held in place by two adhesive strips.
Si votre batterie comprend deux languettes noires à côté des coins inférieurs, la batterie est maintenue en place par des bandes adhésives d'extraction étirables. Si c'est le cas, consultez ce tutoriel pour effectuer le remplacement de votre batterie.
Avant de commencer à faire levier, prenez note que la batterie est maintenue en place par deux bandes adhésives.
