Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
To remove the trigger assembly, depress the trigger with your index finger as if you are using the controller normally. Hold the grey square bracket onside of the controller with your thumb. Keep your fingers in the same place while rotating upwards towards you to remove trigger assembly.
  • To remove the trigger assembly, depress the trigger with your index finger as if you are using the controller normally.
  • Hold the grey square bracket onside of the controller with your thumb.
  • Keep your fingers in the same place while rotating upwards towards you to remove trigger assembly.
Insérez ici votre traduction
