Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Rotate the device 180 degrees so that the bottom of the device is facing you. A ribbon connects the battery on the rear cover, to the motherboard.  Slowly lift the bottom of the rear cover up until you can see the ribbon. Use a spudger to push the ribbon away from the motherboard and parallel to the motherboard in order to remove the ribbon.
  • Rotate the device 180 degrees so that the bottom of the device is facing you.
  • A ribbon connects the battery on the rear cover, to the motherboard. Slowly lift the bottom of the rear cover up until you can see the ribbon.
  • Use a spudger to push the ribbon away from the motherboard and parallel to the motherboard in order to remove the ribbon.
  • Separate the rear cover by lifting it up away from the main system.
  • When reassembling the rear cover to the motherboard, reinserting the ribbon cable with a spudger may prove difficult. In this case, gently use your hands to slide the cable end into the slot until they click into place.
Insérez ici votre traduction
