Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
For your safety, please make sure the device is powered off and the A/C adapter is unplugged. Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel. Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
  • Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel.
  • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
Insérez ici votre traduction
