Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Two silver screws are holding down the aluminium dust cover protecting the display connections. Use the Phillips #0 screwdriver to remove two 3.2 mm silver screws. Use the tweezers to remove the grey cover.
  • Two silver screws are holding down the aluminium dust cover protecting the display connections.
  • Use the Phillips #0 screwdriver to remove two 3.2 mm silver screws.
  • Use the tweezers to remove the grey cover.
  • Under the cover, you will see one white wire and one black wire.
  • Use the tweezers and gently pull straight up on each of the coaxial cables to disconnect them from their specialized brackets.
  • Reposition the tweezers farther up on the wire and pull forward to remove the wires from the plastic guides that hold the them in place.
Insérez ici votre traduction
