Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Use the Phillips #0 screwdriver to remove the two 3.2 mm black screws holding down the cover. Now use the tweezers to carefully remove the silver cover from the backboard. Under the cover you will see the display cable fused to a rectangular adapter.
  • Use the Phillips #0 screwdriver to remove the two 3.2 mm black screws holding down the cover.
  • Now use the tweezers to carefully remove the silver cover from the backboard.
  • Under the cover you will see the display cable fused to a rectangular adapter.
  • Gently wedge the plastic opening pick in between the display cable and the backboard.
  • Gently pry up disconnecting the adapter with the display cable from its bracket.
Insérez ici votre traduction
