Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Pull the IO Bezel off. Don't forget to tighten the screws on the bottom case back up if you won't be removing it later.
  • Pull the IO Bezel off. Don't forget to tighten the screws on the bottom case back up if you won't be removing it later.
  • Getting the IO Bezel back in can be a bit tricky. If you have trouble, you can remove the entire bottom shield to make the task a snap.
Insérez ici votre traduction
