Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
With the home bar out of the way, gently pry up the display using the opening tools. There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing. Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
  • With the home bar out of the way, gently pry up the display using the opening tools.
  • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
  • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
  • Gently lift out the display.
Insérez ici votre traduction
