Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 3
Étape 3
Apply a suction cup to the display, near the middle of the right edge. Pull up on the suction cup with firm, constant pressure to create a slight gap between the display and rear case. If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
Cut the display adhesive
  • Apply a suction cup to the display, near the middle of the right edge.
  • Pull up on the suction cup with firm, constant pressure to create a slight gap between the display and rear case.
  • If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
  • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
  • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
  • Insert an opening pick (or playing card) into the gap you opened behind the display.
  • Do not insert the tool more than 1.5 mm past the edge of the display.
Insérez ici votre traduction
