Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 10
Étape 10
Slice through the glue under the lower bezel. You can insert the pick slightly deeper here, but if you want to re-use the display, don't insert the tool more than 4 mm past the edge of the display. You can insert the pick slightly deeper here, but if you want to re-use the display, don't insert the tool more than 4 mm past the edge of the display.
  • Slice through the glue under the lower bezel.
  • You can insert the pick slightly deeper here, but if you want to re-use the display, don't insert the tool more than 4 mm past the edge of the display.
Insérez ici votre traduction
