Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass. Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass. After being cut, the adhesive will sometimes stick back together as it cools. To prevent this you can leave the pick in this edge after cutting, and continue the next steps with a new pick. Repeat this with each edge, leaving a pick and continuing with a new one.
  • Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
  • Slow down and slice very carefully as you get to the corners. The curved part of the glass along the left and right edges can crack very easily if the pick pushes up against the curved glass.
  • After being cut, the adhesive will sometimes stick back together as it cools. To prevent this you can leave the pick in this edge after cutting, and continue the next steps with a new pick. Repeat this with each edge, leaving a pick and continuing with a new one.
Faites glisser le médiator tout le long du bord inférieur du téléphone pour trancher l'adhésif qui fixe la vitre arrière.
Ralentissez et faites plus attention quand vous arrivez aux coins. La partie incurvée des bords gauche et droit de la vitre est très fragile et risque de se fissurer si le médiator la heurte.
Une fois tranché, l'adhésif risque de réadhérer en refroidissant. Pour éviter cela, vous pouvez laisser le médiator dans le coin et continuer les étapes suivantes avec un nouveau médiator. Répétez à chaque coin : laissez-y un médiator et continuez avec un autre.
