Aller au contenu principal
Remplacement de la carte mère du PowerA Enhanced Wireless Controller
Anglais
Français
Informations sur le tutoriel
= Terminé = Incomplet
    This guide will show you how to access and replace the motherboard of your PowerA Enhanced Wireless Controller.
    This guide will show you how to access and replace the motherboard of your PowerA Enhanced Wireless Controller for Nintendo Switch. Replacing the motherboard is a necessary step for fixing stick drift and power-related issues on your controller. Other motherboard issues are often characterized by unresponsive buttons and your controller failing to immediately turn on.
    Before beginning the repair process, it's important to remove the batteries from your controller to ensure your safety during the repair and prevent any additional issues. Step 1 of this guide will show you how to access the battery compartment to remove the batteries.
      Étapes du tutoriel
      Étape 1
      Retirez le couvercle de la batterie en appuyant sur le levier situé sur le dessus du couvercle.
      Étape 2
      Retirez les huit vis à l'aide du tournevis J0.
      Étape 3
      Insérez l'outil d'ouverture iFixit dans la couture et soulevez doucement la plaque de recouvrement.
      Étape 4
      Retirez les trois vis fixant la carte mère à l'aide du tournevis J00.
