Aller au contenu principal
Remplacement du boîtier de la manette Switch Pro Controller
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Switch Pro Controller Case Replacement: étape 0, image 1 de 3 Switch Pro Controller Case Replacement: étape 0, image 2 de 3 Switch Pro Controller Case Replacement: étape 0, image 3 de 3
  • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
  • Delicately take off the plastic cover from the controller.
  • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
Retirez délicatement le couvercle en plastique du contrôleur.
Ne retirez pas encore complètement le capot avant, car il est toujours attaché à la carte mère via un câble plat blanc.
+[* icon_note] There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
[* black] Delicately take off the plastic cover from the controller.
-[* icon_caution] Do not completely remove the front cover just yet, as it is still attached to the motherboard via a white ribbon cable.
+ [* icon_caution] Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
