Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below. If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier. During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
  • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
  • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
Si vous avez réussi à détacher entièrement le capteur de luminosité ambiante, comme illustré sur la première photo, continuez à l'étape suivante.
Si le diffuseur (la bande blanche) s'est détaché et reste coincé dans l'écran, comme illustré sur la deuxième photo, vous allez devoir faire délicatement levier le long du bord supérieur à l'aide d'une fine lame ou d'un outil à levier. Refaites chauffer d'abord pour faciliter la tâche.
Lors du remontage, insérez d'abord le diffuseur à sa place dans l'écran en veillant à ce qu'il soit bien orienté (vous voyez la partie avant sur la première image et la partie arrière sur la troisième).
Puis posez le capteur de luminosité ambiante sur le diffuseur. Il faut maintenir le diffuseur en place pendant que vous revissez le module haut-parleur interne/capteurs. Une fois les vis bien serrées, le capteur reste en place et fonctionne normalement.
