Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver. Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
  • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
En vous servant d'un tournevis tri-wing, dévissez les vis qui maintiennent la coque arrière au reste de la console. Les six vis à enlever incluent :
Quatre vis tri-wing #00 de 6,45 mm localisées aux coins de la coque.
Deux vis tri-wing #00 de 4,6 mm localisées au milieu du haut et du bas de la coque.
-[* orange] Using the tri-wing screwdriver, unscrew the screws holding the back cover to the device. The six screws that need to be removed include:
- [* orange] Four #00 6.45mm tri-wing screws that are located at the corners of the device.
- [* yellow] Two #00 4.6mm tri-wing screws that are located at the top-center and bottom-center of the device.
+[* yellow] Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
+[* green] Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
