Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Next, remove the ten 5.92mm T5 torx screws located underneath the kickstand. Remove the seven 5.87mm T5 torx  screws located under the camera casing. There is a sticker covering the second screw from the left.
  • Next, remove the ten 5.92mm T5 torx screws located underneath the kickstand.
  • Remove the seven 5.87mm T5 torx screws located under the camera casing. There is a sticker covering the second screw from the left.
  • Disconnect the rear cover from the main shell of the system by loosening it with a spudger where the gaps exist.
  • There is an electrical ribbon connecting the rear cover to the motherboard. Do not pull apart the rear cover from the motherboard once you have loosened the rear cover from the main system.
  • Continue working your way around to each corner and loosen the snap-ons on each side until the rear cover comes off.
Insérez ici votre traduction
