Aller au contenu principal
Tado Smart Radiator Thermostat v3 Plus Teardown
Anglais
Français
Traduction de l’étape 5
Étape 5
Tado Smart Radiator Thermostat v3 Plus Teardown, A Quick Look at the Back of the PCB: étape 0, image 1 de 2 Tado Smart Radiator Thermostat v3 Plus Teardown, A Quick Look at the Back of the PCB: étape 0, image 2 de 2
  • On this side of the PCB you can see several more important objects:
  • In black you see both AA battery connections.
  • The first button (yellow) is the button which is pressed when you screw lock the adapter plate back into the main unit when pairing or changing the batteries. It indicates to the device that it is mounted to a radiator.
  • The second button (teal) is the pairing button.
  • The RF antenna (red)
  • The antenna already mentioned is connected to the CC110L IC (magenta), which is a sub-GHz transceiver.
  • In the last step on the other side of the PCB we saw a Bluetooth IC. On this side of the PCB we can also find the antenna for it (green).
Insérez ici votre traduction
