Aller au contenu principal
Anglais
Français
Traduction de l’étape 11
Étape 11
Gently slide an opening pick under the front-facing sensor cable to slice through the adhesive holding it to the midframe. Use the opening pick to carefully pry the front-facing sensor array away from the midframe. Use the opening pick to carefully pry the front-facing sensor array away from the midframe.
  • Gently slide an opening pick under the front-facing sensor cable to slice through the adhesive holding it to the midframe.
  • Use the opening pick to carefully pry the front-facing sensor array away from the midframe.
Faites délicatement glisser un médiator sous la nappe des capteurs frontaux afin de trancher l'adhésif qui le fixe au châssis.
Faites soigneusement levier avec le médiator pour écarter la rangée des capteurs frontaux du châssis central.
