Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the blue tape that secures the white antenna cable to the battery. Using a spudger, carefully disconnect the white antenna cable.
Battery removal
  • Remove the blue tape that secures the white antenna cable to the battery.
  • Using a spudger, carefully disconnect the white antenna cable.
  • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
  • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
  • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
Insérez ici votre traduction
