Aller au contenu principal
Anglais
Français
Traduction de l’étape 11
Étape 11
Locate a hole that is labeded white wire. Slip in the white wire (neutral wire) into the hole located on left side of the outlet. Tighten the screw down
  • Locate a hole that is labeded white wire.
  • Slip in the white wire (neutral wire) into the hole located on left side of the outlet.
  • Tighten the screw down
  • The white wire (neutral wire) is typically located on left side of the outlet.
  • If there are two holes available, use the bottom hole.
Insérez ici votre traduction
