Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side. Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up. You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
  • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
  • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
Insérez ici votre traduction
