Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Once Complete Television will be displayed on navigation screen Once installed you can easily add A/V inputs (Or Outputs) or Reverse camera inputs to the TV module using the wiring diagram shown to the left. Reverse Camera video is connected to pins 13 and 14 on the White plug.  Pin 13 is video signal and Pin 14 is ground.  The Reverse Camera Switch is connected to pin 17 on the Blue plug
  • Once Complete Television will be displayed on navigation screen
  • Once installed you can easily add A/V inputs (Or Outputs) or Reverse camera inputs to the TV module using the wiring diagram shown to the left.
  • Reverse Camera video is connected to pins 13 and 14 on the White plug. Pin 13 is video signal and Pin 14 is ground. The Reverse Camera Switch is connected to pin 17 on the Blue plug
  • A/V Video INPUT is connected to Pins 6 Video and 15 Ground. A/V Audio input is connected to Pin 4 Audio + Pin 5 Audio -
  • If buying a TV retrofit kit from an online retailer such as Bimmernav.com the proper RCA video input cables with proper BMW cables will be provided http://www.bimmernav.com/url/tv
Insérez ici votre traduction
