Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Open the device with a metal or plastic spudger around the edges as indicated. Remember to work slowly and be careful, as to avoid leaving marks on the rear case or body. Note that on the top and bottom of the device, the noses protrude from the display side into the back cover.
Rear Case Removal
  • Open the device with a metal or plastic spudger around the edges as indicated.
  • Remember to work slowly and be careful, as to avoid leaving marks on the rear case or body.
  • Note that on the top and bottom of the device, the noses protrude from the display side into the back cover.
  • On the sides of the device, the noses protrude from the back cover into the display side. (Opposite from the top and bottom of the device)
  • In order to remove the case, you will have to push the back cover inwards on the top and bottom of the device. On the sides, you will have to pull the the cover out.
  • Marks made on the plastic can be partially removed by pressing the material back.
Insérez ici votre traduction
