Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
Our testing shows that the Taptic Engine and main speaker are interchangeable between the 8 and SE! That means fewer parts to hunt down and cheaper replacements, which is a win for everyone involved. Turning to the battery, the capacity is the same as in the iPhone 8, ringing in at 6.96 Wh. That's up slightly from the original SE's 6.21 Wh, and much lower than the (much larger) iPhone 11's 11.91 Wh.
  • Our testing shows that the Taptic Engine and main speaker are interchangeable between the 8 and SE!
  • That means fewer parts to hunt down and cheaper replacements, which is a win for everyone involved.
  • Turning to the battery, the capacity is the same as in the iPhone 8, ringing in at 6.96 Wh. That's up slightly from the original SE's 6.21 Wh, and much lower than the (much larger) iPhone 11's 11.91 Wh.
  • When Apple retired 3D Touch in the iPhone 11 Pro series, they made the displays a bit thinner and batteries a bit thicker. The new SE also lacks 3D Touch, but the batteries are the exact same size. What was the sacrifice for?
  • Answer: Probably to save money and hit that sweet $399 price point.
  • Alternative answer: Apple wants us to forget that 3D Touch ever happened. We remember.
  • Unfortunately, though the batteries match in size and capacity, the connector has changed—meaning that batteries cannot be swapped between models, unlike the other components seen here.
Nos tests montrent que le Taptic Engine et le haut-parleur principal du 8 et du SE sont interchangeables !
Il faudra donc faire la chasse à moins de pièces détachées et les remplacements seront moins chers, un avantage pour toutes les parties.
Quant à la batterie, sa capacité de 6,96 Wh est la même que celle de l'iPhone 8. Cela représente une légère amélioration par rapport aux 6,21 Wh du SE d'origine et une énorme baisse face aux 11,91 Wh du géant iPhone 11.
Quand les ingénieurs d'Apple ont éliminé 3D Touch de la gamme iPhone 11 Pro, ils ont affiné les écrans et épaissi les batteries. 3D Touch manque aussi sur le nouveau SE, mais les batteries ont toujours la même taille. Pourquoi ce sacrifice alors ?
Réponse : peut-être pour économiser de l'argent et arriver au doux prix de 489 €.
Réponse alternative : Apple souhaitait nous faire oublier 3D Touch. Raté. Nous, on s'en souvient.
Malheureusement, même si les batteries correspondent en taille et capacité, le connecteur a changé. On ne pourra donc pas échanger les batteries des deux modèles, contrairement aux composants cités plus haut.
