Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 11
Étape 11
Back to that 3D Touch-less display—we expected to find a slight but measurable difference in thinness, but it sure doesn't look that way from here. The iPhone 8 display (left) looks pretty much identical to the SE's (right). Are they secretly the same? Not so fast! On 3D Touch screens, we'd normally find a chip on the back that drives the parallel plate capacitors (as seen in our 6S teardown). The iPhone SE display (on the right in this photo) doesn’t have that chip, just a blank window where the chip would be. And the layer of capacitors? We start peeling off display parts in an attempt to confirm...
  • Back to that 3D Touch-less display—we expected to find a slight but measurable difference in thinness, but it sure doesn't look that way from here. The iPhone 8 display (left) looks pretty much identical to the SE's (right). Are they secretly the same?
  • Not so fast! On 3D Touch screens, we'd normally find a chip on the back that drives the parallel plate capacitors (as seen in our 6S teardown). The iPhone SE display (on the right in this photo) doesn’t have that chip, just a blank window where the chip would be.
  • And the layer of capacitors? We start peeling off display parts in an attempt to confirm...
  • Confirmed. No 3D Touch.
  • On the bright side, the two displays are functionally interchangeable, which is kind of amazing considering the difference in hardware—the 8 display works on the SE, and vice versa.
  • Before you get any ideas about adding 3D Touch to your new iPhone SE though, we tried it, and it doesn't work.
Retournons sur l'écran sans 3D Touch. Nous nous attendions à trouver une légère différence d'épaisseur, mais cela n'en a aucunement l'air. L'écran de l'iPhone 8 (à gauche) et celui de l'iPhone SE se ressemblent comme deux gouttes d'eau. Cachent-ils les mêmes dispositions intérieures ?
Pas si vite ! Les écrans 3D Touch comprennent habituellement à l'arrière une puce reliée à des rangées parallèles de condensateurs (cf. la vue éclatée du 6S). L'écran de l'iPhone SE (à droite sur cette photo) n'a pas cette puce, juste un espace vide à la place habituelle de cette puce.
Et les condensateurs ? Nous commençons à décoller les différentes couches de l'écran pour tenter d'en avoir le cœur net…
Nous confirmons l'absence de 3D Touch.
Bonne nouvelle : les deux écrans sont interchangeables, ce qui est impressionnant quand on prend en compte la différence du matériel. L'écran du 8 fonctionne sur le SE et inversement.
Au cas où vous zieutiez l'idée de rajouter 3D Touch à votre nouvel iPhone SE, oubliez ! Nous avons déjà essayé et ça ne marche pas.
