Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Slide the opening pick along the edge of the battery to loosen the adhesive. The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive.  Apply the iOpener for at least two minutes. Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
  • Slide the opening pick along the edge of the battery to loosen the adhesive.
  • The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
  • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
  • Mind the display cables and especially the Force Touch cable which covers the battery in one corner so you don't damage them when levering the battery out.
  • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
  • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
Faites glisser le médiator le long du bord de la batterie pour détacher l'adhésif.
L'adhésif qui fixe la batterie est plutôt mou. Mais si vous avez du mal à enlever la batterie, vous pouvez poser un iOpener chauffé au dos de la montre pour le faire ramollir. Laissez l'iOpener en place pendant au moins deux minutes.
Exercez une force constante et régulière quand vous faites levier sur la batterie pour la décoller de l'adhésif.
Évitez les nappes de l'écran, surtout la nappe Force Touch qui recouvre un coin de la batterie, de façon à ne pas les endommager en sortant la batterie.
Assurez-vous ne ni perforer ni déformer la batterie, car elle risque de prendre feu et/ou d'exploser si elle est abîmée.
N'essayez pas encore de retirer complètement la batterie, elle est toujours branchée à la montre.
