Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
It's likely that the Force Touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display. To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself. Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
  • It's likely that the Force Touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
  • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
  • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
  • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
Il est probable que le joint Force Touch adhère au châssis de l'écran et non au reste de la montre. Dans ce cas, insérez un médiator sous l'écran et détachez soigneusement le joint Force Touch de l'écran.
Pour éviter d'abîmer le joint Force Touch, faites soigneusement levier sous le coin de l'écran. Si le joint Force Touch se déchire quand vous soulevez l'écran ou si les couches du joint se défont, vous aurez également besoin de remplacer le joint Force Touch.
Faites glisser le médiator le long de l'écran pour détacher l'adhésif entre le joint Force Touch et l'écran.
N'enfoncez pas le médiator de plus de 2 mm pour éviter d'abîmer d'autres composants.
