Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 17 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Slide the pick down the right edge of the Surface to slice through the adhesive under the screen. Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
Cut through the screen adhesive
  • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
  • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  • Leave this opening pick in the right edge to prevent the adhesive from resealing.
Insérez ici votre traduction
