Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 17 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 10
Étape 10
Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge. Be careful cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inch (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel. Slide the pick along the left edge of the Surface to cut through the screen adhesive.
  • Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge.
  • Be careful cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inch (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel.
  • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
  • Leave this pick in the left edge to prevent the adhesive from resealing.
Insérez ici votre traduction
