Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the center socket.
  • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
  • The three cables are coded with black sleeves of different lengths. During reassembly:
  • Connect the long-sleeved cable to the center socket.
  • The short-sleeved cable connects next to the screw.
  • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Insérez ici votre traduction
