Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 12 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
Use your Torx driver to remove the two outer 6.5 mm screws securing each of the two display brackets to the upper case (4 screws total). Mid 2009 models require a T6 Torx driver, while Mid 2010 models require a T8.
  • Use your Torx driver to remove the two outer 6.5 mm screws securing each of the two display brackets to the upper case (4 screws total).
  • Mid 2009 models require a T6 Torx driver, while Mid 2010 models require a T8.
Dévissez les deux vis extérieures Torx de 6,5 mm fixant les deux supports de l'écran au boîtier supérieur (4 vis au total).
-[* red] Remove the two outer 6.5 mm Torx screws securing each of the two display brackets to the upper case (4 screws total).
+[* red] Use your Torx driver to remove the two outer 6.5 mm screws securing each of the two display brackets to the upper case (4 screws total).
+ [* icon_note] Mid 2009 models require a T6 Torx driver, while Mid 2010 models require a T8.
