Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 12 tutoriels qui comprennent cette étape.
Traduction de l’étape 8
Étape 8
Open your MacBook so the display is perpendicular to the upper case.
Place your opened MacBook on a table as pictured.
While holding the display and upper case together with your left hand, use your Torx driver to remove the remaining 6.5 mm screw from the lower display bracket.
[* black] Open your MacBook so the display is perpendicular to the upper case. |
[* black] Place your opened MacBook on a table as pictured. |
[* red] While holding the display and upper case together with your left hand, use your Torx driver to remove the remaining 6.5 mm |
