Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 12
Étape 12
Remove the following Tri-point screws securing the battery to the upper case: One 5.5 mm Tri-point screw.
  • Remove the following Tri-point screws securing the battery to the upper case:
  • One 5.5 mm Tri-point screw.
  • One 13.5 mm Tri-point screw.
  • Lift the battery out of the upper case.
Dévissez les vis tri-wing suivantes, fixant la batterie au boîtier supérieur :
Une vis tri-wing de 5,5 mm.
Une vis tri-wing de 13,5 mm.
Ôtez la batterie du boîtier supérieur.
-[* black] Remove the following tri-wing screws securing the battery to the upper case:
- [* red] One 5.5 mm tri-wing screw.
- [* orange] One 13.5 mm tri-wing screw.
+[* black] Remove the following Tri-point screws securing the battery to the upper case:
+ [* red] One 5.5 mm Tri-point screw.
+ [* orange] One 13.5 mm Tri-point screw.
[* black] Lift the battery out of the upper case.
