Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 3
Étape 3
Slide the spudger between the orange ribbon and black connector.  Flip the black connector upwards to release the orange ribbon. Using the spudger, pull the orange ribbon away from the connector to confirm the wire is fully disconnected.
  • Slide the spudger between the orange ribbon and black connector. Flip the black connector upwards to release the orange ribbon.
  • Using the spudger, pull the orange ribbon away from the connector to confirm the wire is fully disconnected.
Faites glisser le spundger métallique entre le ruban orange et le connecteur noir. Retournez le connecteur noir vers le haut, libérant le ruban orange.
Retirez le ruban orange du connecteur afin de vous assurer que le fil est complètement déconnecté.
[* yellowred] Slide the metal spundgerspudger between the orange ribbon and black connector. Flip the black connector upwards, releasingupwards to release the orange ribbon.
[* red] Pullorange] Using the spudger, pull the orange ribbon away from the connector, in orderconnector to make sureconfirm the wire is fully disconnected.
